mondphase
firefox
@ riccione
.... siehste ich hatte doch recht:
http://www.computus.de/mondphase/mondphase.htm
... und um den dreh rum wenn der so voll leuchten will (ca 6 tage) mach ich immer so nen scheiss - bloss tanzen kann und will ich net
It’s Close To Midnight And Something Evil’s Lurking In The Dark
Under The Moonlight You See A Sight That Almost Stops Your Heart
You Try To Scream But Terror Takes The Sound Before You Make It
You Start To Freeze As Horror Looks You Right Between The Eyes,
You’re Paralyzed
‘Cause This Is Thriller, Thriller Night
And No One’s Gonna Save You From The Beast About Strike
You Know It’s Thriller, Thriller Night
You’re Fighting For Your Life Inside A Killer, Thriller Tonight
You Hear The Door Slam And Realize There’s Nowhere Left To Run
You Feel The Cold Hand And Wonder If You’ll Ever See The Sun
You Close Your Eyes And Hope That This Is Just Imagination
But All The While You Hear The Creature Creepin’ Up Behind
You’re Out Of Time
There Ain’t No Second Chance Against The Thing With
Forty Eyes
You’re Fighting For Your Life Inside Of Killer, Thriller Tonight
Night Creatures Call
And The Dead Start To Walk In Their Masquerade
There’s No Escapin’ The Jaws Of The Alien This Time
(They’re Open Wide)
This Is The End Of Your Life
They’re Out To Get You, There’s Demons Closing In On Every Side
They Will Possess You Unless You Change The Number On Your Dial
Now Is The Time For You And I To Cuddle Close Together
All Thru The Night I’ll Save You From The Terror On The Screen,
I’ll Make You See
That This Is Thriller, Thriller Night
‘Cause I Can Thrill You More Than Any Ghost Would Dare To Try
Girl, This Is Thriller, Thriller Night
So Let Me Hold You Tight And Share A Killer, Diller, Chiller
Thriller Here Tonight
RAP >>>>> hier kommt dein moonwalkereinsatz
Darkness Falls Across The Land
The Midnite Hour Is Close At Hand
Creatures Crawl In Search Of Blood
To Terrorize Y’awl’s Neighbourhood
And Whosoever Shall Be Found
Without The Soul For Getting Down
Must Stand And Face The Hounds Of Hell
And Rot Inside A Corpse’s Shell
The Foulest Stench Is In The Air
The Funk Of Forty Thousand Years
And Grizzy Ghouls From Every Tomb
Are Closing In To Seal Your Doom
And Though You Fight To Stay Alive
Your Body Starts To Shiver
For No Mere Mortal Can Resist
The Evil Of The Thriller
Aaaahuuuu !!!
Guter Geschmack!
Hallo Markus,
klingt doch gut, wie bei Frankenstein unterm Sofa. Wenn Du solche Texte kennst/magst, liest Du sicher auch Bücher von Dean Koontz, der m.E. stärker ist, als der so vielseits gelobte Stephen King, mit dem ich persönlich aber wenig anfangen kann.
Keep swinging, komm mal mit Deinem Surfboard - das, das Du neulich in einem anderen Thread gepostet hattest - in den Genfer See, ich spendiere dann zum sundowner einen Hauch von Agent Orange, das wirst Du sicher auch lecker finden.Ciao, Euer
Salzburger
frei nach Brecht:
@salzburger
dean koontz hab ich leider noch nichts gelesen, hab aber schon mehrfach gehört dass dieser tolle bücher schreibt und auch nochn tick besser sein soll als sk - von dem ich allerdings in früherer jugend mehreres gelesen habe - fantastisch: es
... sundowner klingt gut - aber mit agent orange hab ich aufgehört als ich feststellte dass die platane in nachbars garten immer noch blätter trägt mir aber die haare ausgehen
8) :shock: - bin quasi weg von der droge und nehm lieber auf anraten der frauen meines arztes und apothekers ne 0,5er weizenkaltschalte, oder ein viertele rotwein als schlummertrunk
